跳转到主内容
加入维修社区 - 创建账户
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
Why my MacBook 12'' A1534 not powering on
My macbook was working fine, then all of a sudden I got some disturbance on the screen, like when we have a bad RAM.
In panic, I forced it power off by pressing power button. Now am trying to start/boot it and nothing happens. No chime, nothing on display absolutely nothing.
Tried connecting external monitor using a dongle with HDMI, still nothing.
Also, if I leave it on (power button one time pressed) laptop gets heated up from below. Also light in one of my dongle (with HDMI connection) turns on and off when power button is long pressed.
Apple is asking INR 65K for logic board replacement. Already got it done twice (once in warranty). Cannot go again.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Sadly the Retina MacBook's logic boards overheat and die.
Remember this was an experiment on how tight they could pack a logic board, Even today it's the most densely packed Intel Core M system.
Sorry there is nothing you can do to fix this other than replace it once again ;-{
完成的
添加一条评论
1个答案
This does sound like a logic board issue. However as a first step you can try to remove the bottom cover and check if all the cables are still connected properly. If everything looks okay I would recommend to take the board to a repair shop that can also do microsoldering, since there might be some issues on the board (e.g. blown capacitor).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amit Kumar 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 18
总计 674
