跳转到主内容
Bluetooth on-ear headphones with 40 mm drivers and a 610 mAh battery. Released in 2014.
21 个问题 查看全部
speaker and battery cable replacement
Hi, my headphones stopped turning on, after searchin i found it's because cable conecting main board with battery and speaker is broken and connected battery positive with speaker. I need help with tear down, i dont know ho to open plastic slider.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @jonasskuhrovec
I don't see any other options but unscrewing that golden bolt. Have you tried it?
完成的
添加一条评论
1个答案
You can disassemble the earpieces. These consist of screws and plastic tabs. You already did (most of) that.
I don’t know a way to open the headband in case you need to replace that cable.
You can try to push or pull new wires through.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jonáš Skuhrovec 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 80
