跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
To remove the blue sheet or not?
I just bought a keyboard replacement (part # IF123-120-1) for my early 2015 retina macbook pro, and in installing the main keyboard ZIF connector its unclear if the blue protective sheet need to come off of the plug on the keyboard. Im used to seeing gold plated contacts, but these are black on top and silver on bottom. the silver ones are covered by the blue tape. Using a multimeter, the upper black side shows electrical conductivity while the bottom side does not, even when i peel back the sticky blue tape. I’m wondering if the tape is there to increase thickness so it stays tight in the ZIF connector or if it needs to be removed. If so, why does it leave a sticky film behind on the silver contacts that appear to not be conductive? Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Could you add a photo of the issue?
The film you see might be some glue residue due to low quality glue
完成的
添加一条评论
1个答案
最有帮助的答案
The Blue sheets cover the adhesive pads and need to be removed to mount the backlight.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Seth Waag-Swift 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 108
