Truck died while driving now won't run
Had to floor the gas pedal to merge into highway suddenly oil pressure dropped. Oil pressure gauge fluctuated for a week until I was driving about to shift into reverse when it died now won't run no spark
I would replace the oil pressure sensor. If it fails the fuel pump will turn off. The oil pressure sensor is hooked up to the fuel pressure relay and if you don't have oil pressure it will kill the fuel pump relay which will turn off the fuel pump. This is to stop the engine from damage if you lose oil pressure. The way it's been acting it sounds like the sensor. That's where I would start, I would get a fuel gauge and check the fuel pressure. I would also get a scanner and check for computer codes. I'm don't know what mechanical skills you have but GM vehicles have a test port in the fuel line on the engine. Autozone might be able to lend out the fuel pressure gauge. When you turn the key on to the rin position (not start) it will give the fuel pump a 2 second power signal to prime the fuel line. After that you will have to crank the engine to get fuel pressure to come up. You will have to look up the fuel pressure for your vehicle. If the fuel pressure doesn't come up it's most likely the oil pressure sensor.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 16
总计 536
Hi @tommygunn0170 ,
Have you checked the oil level in the engine is OK, you didn't say?
Does it turn over when trying to start it?
由 jayeff 完成的
I agree with jayeff. Check the oil level in the engine by using the dipstick. If there is no oil then your motor is probably seized and needs a rework or a replacement.
由 bloggerstomper 完成的
@jayeff It turns over but wont run
由 Tommy Chancey 完成的
@tommygunn0170
Have you checked if there is fuel getting to the engine?
Can you hear if the fuel pump is operating?
What is the year model of the vehicle?
由 jayeff 完成的
@jayeff I believe it's getting fuel at the engine. 1996 k2500 400gmt
由 Tommy Chancey 完成的
显示更多的1条评论
