跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Issues with keyboard (2 sets of three keys unresponsive)
I bought a second hand MacBook Pro, there are 6 keys that don’t work: Q, 1 and lower brightness and backspace, volume up and volume down (I’ve grouped them in threes because of their very close proximity to each other). I’ve reseated the keyboard connector on the logic board and even cleaned the contacts but no joy. There is no noticeable liquid damage I found whilst inside the MacBook and the actual keys seem perfectly in order. I was just wondering given the two sets of three unworking keys if it’s worth replacing the keyboard entirely or likely an issue somewhere else?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sorry there is little you can do here to fix these keys discreetly!
Keyboards are a bunch of mechanical switches which over time can just wear out! In your case there is some junk which has gotten onto the keyboard backplane which routes the discreet keys electrical connections into what the system can accept as an input.
So you have two paths here either replacing the full uppercase while being more expensive is the quicker and easier way MacBook Pro 15" Retina (Mid 2012-Early 2013) Upper Case Assembly or replacing the discreet keyboard which is much harder but cheaper! MacBook Pro 15" Retina (Mid 2012-Mid 2015) Keyboard
For either you’ll need to follow this guide MacBook Pro 15" Retina Display Mid 2012 Upper Case Assembly Replacement then removing the keyboard backlight and then you will need to fight through all of the 50+ screws (some have rivets as well).
Just consider your skills, the value of your time vs costs!
Replace an upper case and keyboard compatible with the Mid 2012 to Early 2013 Retina 14" MacBook Pro laptop.图片
产品
$89.99
Replace a damaged, dirty, corroded, or malfunctioning keyboard compatible with a model A1398 15" MacBook Pro with Retina display from Mid 2012 to mid 2015.图片
产品
$19.99
这个答案有帮助吗?
得分 0
2条评论:
Hi, thanks for this! I'm used to board repair and I'm familiar with computer hardware but have up until now only owned a 2008 unibody MacBook which was much easier to repair. I just wanted to know anyone's thoughts on this used upperboddy as opposed to me spending £13 on a keyboard for the sake of saving time. Thanks again https://www.ebay.co.uk/itm/143867797802
完成的
@caimenjackson - That works too!
完成的
添加一条评论
添加你的答案
Caimen Jackson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 67
