跳转到主内容
2018年7月发布,15英寸 MacBook Pro,型号 A1990,拥有True Tone技术的LED背光15.4英寸显示器,最高6核心的酷睿 i7 处理器。
How do I remove the bottom?
I just want to clean up the inside of my MacBook Pro 15” A1990 that I have had for 2.5 years, but after unscrewing the 6 screws and undoing the internal clips, I can’t get the bottom to slide off.
I have seen numerous guides and they all show the same thing: After undoing the clips, they slide the bottom down from the hinge and it comes off easy. But when I try sliding down, it doesn’t budge even slightly.
It may be worth noting that the Apple Genius Bar has done a repair on this MacBook in the past.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It definitely takes a little more force than you would expect, but the aluminum bottom cases are quite durable and the tabs are meant to slide out. However, if you’re uncomfortable I’m sure a local repair shop can help you open it up.
这个答案有帮助吗?
得分 0
2条评论:
Alright I think I’ll keep trying... Are you sure the Apple Geniuses wouldn’t have put adhesive on the tabs after servicing it?
完成的
Nevermind! I opened it! Thanks.
完成的
添加一条评论
添加你的答案
Jacob Kowanetz 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 110
