iMac G3 (Slot Loading) screen or motherboard problem.
Hi.
Me and my dad bought an imac g3 but it came shattered in cargo. I tried to run it in broken state, it worked and it was ok, then we completely removed the inside of it, repaired the CRT bezel and cleaned the boards. This process took 2 weeks and when we try to operate it today, the power light is on. The CRT tube is warming up, an electric field occurs, but there is no starting sound and the screen is not coming. I'm sure all cables are plugged in but it doesn't work
is resisting.
(Sorry for the bad English i translated it from my language)
Hi @ado41
Check memory and try reseat.
Maybe need to check the PRAM battery.
由 Augustine 完成的
I checked the battery now and yes its dead but is it bad for booting?
由 Aydın Yavuz 完成的
Hi @ado41 try replacing and see if it works. iirc .... read up and check that a dead pram battery may cause bootup issues
由 Augustine 完成的
I changed the battery but it didnt worked :(
由 Aydın Yavuz 完成的
