I thought this post came under Pro 12.9 so the location of the 2nf would be known. I am new to the forum, so to be clear, it is on a 12.9 Gen 1. Hope that helps.
Not sure I want to remove the capacitor as there is also a capacitor in between the two back light filters. I’m thinking there’s a reason for those to be there. The main reason I posted this is because they are so easy to knock off and lose when you’re changing out the touch filter.
2nF is the Capacitance what about Working voltage, Tolerance and size?
由 Chris Stables 完成的
I have no idea, I got the spec from the image posted by one of the members here (old man??)
was hoping someone had already found it on iPhone boards
由 Steven Whatley 完成的
The chances are you don't need a capacitor there.
由 Roman Prochazka 完成的
