跳转到主内容
A1708/EMC 2978—于2016年10月上市,这台入门级MacBook Pro保留了它传统的功能键(相对于OLED触摸条)。功能键版本带有英特尔酷睿i5和2个雷电3端口。
216 个问题 查看全部
Why do purple lines appear past 25 degrees?
My computer is showing large, vertical purple lines (and one grey/green one) but only when I open the screen past 25 degrees. When I close the screen below 25 degrees, everything works fine. I have had a few different problems with this computer in the past which have been fixed under repair programs (keyboard replacement and display backlight repair).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
What does an external display show you? Do you see a clean image.
完成的
@danj ya it works fine when hooked up to my tv
完成的
添加一条评论
1个答案
Well, thats a bit of good news! Your display is only effected.
You likely cooked your T-CON board which has been a problem in this series. Sadly, it’s been a big problem so you can only get new display assemblies!
Here’s the guide to replace it: 2016年后期13寸MacBook Pro功能键版本显示屏组件
Here’s a bit more on the why Screen issues - white/negative screen fixes itself after update In your case the tilting of the lid is either cutting off the air flow or adding stress to the T-CON board connections.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel Madden 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 118
