跳转到主内容
Battery charges and is seen by OSX but will not power MacBook A1466
I have two computers that are identical model and year A1466 2014.
One is a client’s and the other is my personal. I used a part on my personal to diagnose an issue on the clients machine, turns out it was just a damaged keyboard cable.
Now upon putting my MacBook air back together the battery will not power the machine. OS-X recognizes the battery and can charge it but as soon as the plug is pulled the computer shuts off. It won’t turn on, on battery power either.
I have swapped batteries and same problem. Both batteries work fine in the other MacBook. The other battery will not power my MacBook. I have tried SMC and PRAM resets multiple times.
I have examined the port where the battery plugs in on the logic board and there is no damage. I have checked the voltage in several places on the logic board and it is giving me the proper reading in all areas.
It was working absolutely fine before and I have dissembled this MacBook several times with no issues.
Any thoughts or advice would be appreciated
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would check the Keyboard cable which is connected into the trackpad MacBook Air 13" Early 2014 Trackpad Replacement I would also try swapping out the trackpad as well.
这个答案有帮助吗?
得分 0
2条评论:
Unfortunately that had no effect
完成的
You replaced the trackpad?
完成的
添加一条评论
添加你的答案
Cody V 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 43
