跳转到主内容
加入维修社区 - 创建账户
Battery decrease after replacing
I recently just replaced the battery. After only 7 charges the new battery is already at 97% capacity despite staring at 107%. Is this one just defective or what? I did calibrate it correctly as well.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
完成的
@danj image added
完成的
添加一条评论
1个答案
Well, the good news your issue is not the battery! Your charging logic on your logic board has failed! Often we find a knockoff charger burns the comparator logic so SMC can’t tell what’s going on so it just stops!
You’ll need to get your system to someone who can fix your logic board and a new charger, here’s the only source I trust Apple 60W MagSafe 2 Power Adapter (MacBook Pro with 13-inch Retina display) what is sold on Amazon or eBay are 95% knockoffs! Even when the seller says otherwise!
Here’s more on the affliction with knockoff chargers:
这个答案有帮助吗?
得分 0
7条评论:
Strange, for I am using an official Apple charger.
完成的
@tyefr78 - Even I can't tell which is which visually! The only way I know of is using a good scale and weighing a known real unit and the one in question. The heaver unit was the real one.
完成的
Oh, no this is one I bought from the Apple store.
完成的
Then you must have gotten your system wet at some point as the SMC chip and the resistors it depends on to compare the level are near it and some what exposed to drips from the keyboard area.
完成的
Ah, okay, thanks. Would you recommend bringing it in to a repair shop or am I besting a dead horse at this point?
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Tyefr78 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 100
