跳转到主内容
Repair guides and disassembly information for the Pebble Time Steel smartwatch.
3 个问题 查看全部
Can I use the Ifixit Pebble Time guides to repair the Time Steel?
I’ve noticed that their are several repair guides for fixing the Pebble Time but virtually none for the Time Steel. From what I’ve seen the internals look nearly identical. Are the internals similar enough that I can just use the Time guides when repairing a Time Steel?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
最有帮助的答案
Sorry to have discovered and answered this so late, but the answer is yes. They are nearly identical. There is, however, a difference in the battery height dimensions, which you can see in the plastic shim between the two layers of the Steel, yielding its 250mAh capacity. Also, the Time Steel’s screen is bonded to the glass. rather than separate from the frame.
Part number for the battery is SP551923AE. Looks like there might be replacements available from AliExpress; maybe not…
Dimensions I measured for the battery were:
19.5mm width
22.5mm height
5.5mm thick
With that in mind, I bought the following Lithium batteries:
602020
502020
Sadly realized the T-shaped pressure pad was nonstandard. Tried soldering to it and messed up. Ended up just buying a PTS with a broken screen on ebay and using its battery. You could also swap in a regular Time’s battery, but just get reduced battery life. Somebody else suggested: there’s a lot of replacement battery on internet. Just search “150mAh P11G7T-01-S01”. Would work with reduced battery life.
Best of luck.
这个答案有帮助吗?
得分 2
添加一条评论
My watch display is broken
这个答案有帮助吗?
得分 0
添加一条评论
Hey folks, just tagging into this as it seems to be about battery replacements - the best info I've found is actually on a reddit thread here: https://www.reddit.com/r/pebble/comments..., where it talks about batteries that work and a few other bits and bobs that are helpful :)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
joshua simpson 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 10
总计 729
