跳转到主内容
LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
46 个问题 查看全部
Does the iFixt IPad 5th gen LCD replacement has a protective film?
I have received day ago my “new” LCD screen from iFixit.
My first impression is the LCD surface has scratches and dust, which is surprising because I ordered a NEW one. Also, I’m not sure if the scratches are over the protective film, because I’m not sure if it has one. There is no easy way to know if it comes with a protective film because it has no tabs to pull it over.
Does anybody has a recommendation?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
It more than likely has a protective film. If you get something like a toothpick or even fine tipped tweezers you can kinda get under it at one of the corners. Just did an iPad 6 LCD (which is also shared between the Air 1 and iPad 5) last week and it too had a film on it.
这个答案有帮助吗?
得分 1
1条评论:
Thank you Jesse!
Certainly it had a protective film.
Now I have to deal with a touchscreen issue... I have changed the LCD and the touchscreen and now the touchscreen is erratic, looks like the bottom quart of the screen is not responding.
Thanks again and take care!
完成的
添加一条评论
添加你的答案
ferbarragan88 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 37
