跳转到主内容
加入维修社区 - 创建账户
LG TrueSteam 干衣机的维修和服务信息。型号 DLEX3570V、WM3670HRA 和 DLEX3570W 分别对应石墨灰、红色和白色。
CL error code L G front load dryer
CL code stays on. Stands for child lock but my model does not have a button on the panel
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
My model number is dlex3700v
由完成的 分享
The clean filter light is on but the code cl is showing
由完成的 分享
添加一条评论
2个答案
最有帮助的答案
Hi @coachvic,
What is the model number of the dryer?
If it is a DLEX3570V or DLEX3570W then press and hold the Easy Iron button for 3 seconds to either lock or unlock the controls.
If it is a WM3670HRA then press and hold the Pre Wash child lock button for 3 seconds
这个答案有帮助吗?
得分 1
添加一条评论
Hi @shawn03 ,
Activating the Control Lock Function:
Press and hold the Wrinkle Care button for 3 seconds. The Control Lock icon will be shown in the display and all controls will be disabled except the Power button.
Deactivating the Control Lock Function:
Press and hold the Wrinkle Care button for 3 seconds. Once set, Control Lock remains active until it is manually deactivated. Control Lock must be turned off to run another cycle.
Clean Filter Reminder:
The display will show Clean Filter when the dryer is turned on as a reminder to clean the filter. It turns off
when the Start/Pause button is pressed..
这个答案有帮助吗?
得分 1
1条评论:
Thank you for your two suggestions on how to turn off the CL feature on my
LG dryer. I was just about ready to pull out, what little hair that I have left.
由完成的 分享
添加一条评论
添加你的答案
Victor Turselli 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 52
总计 13,576
