跳转到主内容
Epson's L220 is ideal for home and home office users looking for good-quality, ultra-low-cost printing, scanning, and copying. Released around 2016.
9 个问题 查看全部
问题已关闭
"Multi-page feed error" keeps popping up with my Epson L405 Printer.
(The don’t have an Epson L405 option) Every time I print a document with multiple pages the multi-page feed error would keep popping up and I have to press the copy button every time to continue printing again. I tried setting the default document size the same as the document’s size and the error still pop-ups.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
3条评论:
Sorry for my bad English :)
完成的
Does the "Multi-page feed error" message appear on your computer screen or on the printer's display panel?
完成的
It appears on the computer screen
完成的
添加一条评论
3个答案
If the error appears in your computer and not on the printer itself, the issue may be the printer's driver. Try uninstalling the current printer driver and then installing one from Epson's Website at the link below:
https://www.epson.com.sg/Ink-Tank-Printe...
这个答案有帮助吗?
得分 0
2条评论:
I uninstalled and installed the driver again, it didn't work D;
完成的
It could be that many pages were fed to the printer at once. Try removing all the printer paper from the tray, putting it it back, and then pressing the color button on the printer.
完成的
添加一条评论
Even I had the problem with my L485. The only solution is to keep less number of paper in the feeder and check if the paper's corners are not bent
这个答案有帮助吗?
得分 0
添加一条评论
i have same problem with epson l3150 ,everything else work fine but in double side printing it gives error -multi feed error but there is no paper stuck ,if i print odd/even print then it works fine
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 5
总计 1,382
