跳转到主内容
Repair guides, disassembly information, and troubleshooting for the Logitech Surround Sound Speakers Z906 (released 2010).
Logitech Z906 will not turn on?
I have 2 Logitech Z906 systems that have been working properly. One now will not turn on, no lights, nothing.
I have checked the fuse and power to the end of the input plug, All seems fine. I did see somewhere about holding the power button on the remote for 8+ seconds to reset but this didn’t do anything either.
Anyone help please, I’m perfectly competant to pull it apart; although not an electrician I am an engineer and could probably/possibly fix it with guidance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
Hi @krisdvv
You will need to open up the defective and inspect the board.
I have a feeling the internal SMPS might be having issues, inspect the smd components carefully. somehow i think something must has shorted and burnt the smd resistors
完成的
OK I thought something like that, but I have no idea what I'm looking for or how to test it?
完成的
I Have the same issue. Got in touch with Logitech for help but they said they don’t have a repair place and could not help. Need help as I am confused why mine just stopped working.
完成的
I have attached some images to see if anyone can figure whats wrong
完成的
@Tony Whyte
There are no images be shown.
Ask a NEW question on ifixit and attach the images to it.
Here's how to 在已经存在的问题里加入图片 on ifixit. It is the same procedure for a new question
Moderator.
完成的
显示更多的2条评论
添加一条评论
4个答案
最有帮助的答案
HOW TO FIX IF SUBWOOFER IS OK BUT CONTROL UNIT NOT WORKING : Attempt 1) Turned on unit, got zero lights. Tried the Logitech Factory Reset (Turn off control unit, then hold the input button for 8 seconds) and saw 2 input lights turn on, but no sound. Tried this procedure several times, and got 3 inputs lights, then tried again, now with 4 input lights on, but again no sound or other lights. Attempt 2) Disconnected power to subwoofer for 30 seconds, and tried Factory Reset again, with same results as Attempt 1, but now with 3 input lights on. Attempt 3) Disconnected cable from Control Unit to subwoofer, waited 30 seconds, tried Factory Reset yet again, with same results as Attempt 1. Attempt 4) Disconnected power to Subwoofer and Control Unit cable. Waited 60 seconds and tried Factory Reset again, and got same results as Attempt 2 - No Joy. Attempt 5) Found this video, and although was not that helpful, tried Attempt 4 yet again several more times and on the last try, this time it works, and my Z906 is back to normal ! Lesson Learned : You may have to power the subwoofer down and disconnect the control cable and then try the Factory Reset Proceedure more than a few times to get your Z906 back into its working state !
Show less
这个答案有帮助吗?
得分 4
4条评论:
This actually worked for me! Turned PC on in the morning no sound, Z906 would not power on.
Powered unit off for 30 seconds and then held input down until lights came on. Boom, fixed.
Thanks Dave!
完成的
Worked in first attempt.. Thanks.. 😊🙏
完成的
It also worked for me but the problem is my Z906 keeps shutting off and i have to power off the subwoofer and then hold the input button for 8 seconds each time the Z906 shuts off to get it working again. Has anyone have any idea why my Z906 keeps shutting off?
完成的
Uplugging worked for me, waited a bit for all the capasitors to discharge and plug back in
完成的
添加一条评论
Had the same issue with my z906. Visited a shop who took half an hour to replace a part that was used as a safeguard to protect the motherboard from overvoltage. He then said that he added an additional safeguard which looked like a small blue balloon, that if in future there is an overvoltage, only that part need to be replaced, and that will take only a few minutes.
这个答案有帮助吗?
得分 1
1条评论:
What king of a shop did you take it to as I would like to get mine fixed ??
完成的
添加一条评论
Power Loss Issue, power error
这个答案有帮助吗?
得分 1
3条评论:
Samé thing happend to me.. In the servis shop they: we are sorry but we cant fix them😕 so i dont recomende those speakers
完成的
i can help you, but i am in vietnam
完成的
Power on off automatic
完成的
添加一条评论
Hi @krisdvv ,
Post some close up images of the board(s) back here and hopefully someone will spot what you can't.
Here's how to do this on ifixit 在已经存在的问题里加入图片
The 3 images in Reply post #30 of this link shows what the damage may look like in your speakers if it suffered from the same problem but maybe not. Click on the images to get a close up view
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kris 将永远感激不已
浏览统计数据:
过去 24 小时: 6
过去 7 天: 62
过去 30 天: 315
总计 12,863
