跳转到主内容
27“显示屏,分辨率为2560 x 1440像素 Thunderbolt&MagSafe电缆附件
160 个问题 查看全部
Thunderbolt Display issues after replacing Thunderbolt/Magsafe Cable
Hello -
I need assistance. I replaced my Thunderbolt Display Thunderbolt and Magsafe Cable following these directions... Apple Thunderbolt Display Thunderbolt & MagSafe Cable Replacement It was very easy even with my inexperience. Really, the hardest part was trying to keep the screen clean when putting it back on (it’s still streaky but not facing a window, so whatever, hahaha).
But now when I connect the Thunderbolt Cable, the screen flickers and moves around like crazy and goes black randomly. The other parts of the cord and display work as expected, the USB ports connect, the camera and sound work, and the Magsafe is charging my laptop.
I know I didn't damage the logic board as when I plug in a stand alone Thunderbolt Cable to the port on the back of the display to my laptop the screen works fine, I just don't get the camera, sound, and USB ports. I tried restarting my laptop, resetting SMC, and resetting PRAM.
Does anyone have any advice? My cousin thinks maybe the cable wasn't pushed in all the way on the back of the logic board, but would the camera, sound, and USB still work if that was the case? Or maybe I just have a faulty replacement cable? Could the Thunderbolt port on the logic board be bad? What should I check next?
Thank you,
Lindsay
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It could also be just a bad part.
这个答案有帮助吗?
得分 0
2条评论:
After a lot of trial and error, it's definitely the replacement cable!
完成的
If you're set don't forget to accept the answer - Thanks!
完成的
添加一条评论
添加你的答案
Lindsay 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 147
