跳转到主内容
The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
124 个问题 查看全部
Can I use glue to reattach the front screen on apple watch series 1
The adhesive double sided tape does not stick even when fitted correctly. what type of glue can I use instead of tape and would the touch sensor still work when glue is applied on top of it. I have B-7000 glue.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
As long as you don’t put too much on, the glue you have should be fine. The force touch sensor will still function normally.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
robynannfraser 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 18
过去 30 天: 87
总计 2,035
