跳转到主内容
加入维修社区 - 创建账户
三星新旗舰的大号版本,盖乐世S8+。发布于2017年4月。
Why is my s8+ keep freezing and rebooting?
Hello everyone,
My Samsung S8+ suddenly started to stuck at the boot screen and every force restart, hard reset and wipe cash attempts didn’t solve the problem.
I tried to flash the firmware and the download procedure has done smoothly through Odin, then the phone started normally and I reached the home screen,
but it keeps freezing and rebooting every few minutes (or sometimes it even reboots in the Samsung logo screen), and sometimes it continues to work perfectly for more than 10 minutes but then it freezes and reboots
I tried the safe mode but all the same
ps: the screen was replaced many months ago
phone info:
SM-G955F
anyone have an idea ?!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
still no answers …
完成的
I have the same problem, do you get any graphical glitches right when the phone freezes?
完成的
So is there any solution? i have the same problem..
完成的
I have the same problem but it never works for longer then a minute.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi @wesamoooo11
So you had no problems during the reflashing of the phone using Odin i.e. no glitching or freezing etc, only afterwards, is this about right?
Was the phone still connected to an external power source i.e. USB cord connected to the computer when the problems started afterwards or not?
If not, I'm wondering if it is a power problem with the battery.
Try leaving the charger connected and check what happens.
If it still happens then there is a hardware problem of some kind. Has the phone been dropped or gotten wet at all?
Update (01/22/2021)
Hi @wesamoooo11
The only thing left to do now, as you have tried all the software remedies, is to open the phone and check that all the connections are secure and that there is no obvious physical damage to the boards or components.
Here's the ifixit Samsung Galaxy S8 Plus guide that will help you to do this.
If doing this seems too daunting, contact a reputable, professional mobile phone repair service and ask for a quote.
这个答案有帮助吗?
得分 2
1条评论:
Thanks for your responding
- Nothing wrong happening during flashing, neither glitching nor freezing, it all goes perfectly
- the problem happens regardless being connected to an external power source or not, it even sometimes happened during booting
- I tried to leave the charger connected but the problem still happened
yes the phone dropped but I don't remember if the problem started to appear at that point
完成的
添加一条评论
添加你的答案
Wesam Alhusain 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 1,168
