跳转到主内容
发售于2017年9月22日。型号为 A1863, A1905。有 GSM 或者 CDMA 网络制式可选。提供64或者256GB 的存储空间。提供金色、银色和深空灰色。
Boot loop after changing screen
I replaced a badly damaged screen and I don’t get anything when I try to power it on but when I connect a lightning cable I just get a boot loop. I have already tried to disconnect the proximity sensor and turn it on and it still doesn’t work. Any idea?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Sounds like a battery problem. If the battery was working before you will need to check the battery connector on the logic board. These have a habit of failing due to one of the pins being pushed into the plastic. There are also some components around the battery connector that if nudged could cause this issue.
 You could also try putting pressure on the top of the battery flex connector and see if it boots. If the battery wasn’t very good before the screen replacement I would replace the battery.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Adam Baker 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 122
