跳转到主内容
15.6", Intel HD Graphics, Core i3 2330M, Windows 7 Home Premium 64-bit, 4 GB RAM, 500 GB HDD
I have a problem with the processor fan working
When I turn on the device, I hear a violent sound of the fan that lasts for 4 seconds, with the device vibrating violently And also when I play or do a task on the device, knowing that I have cleaned the dirt.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
Here’s the service manual for the laptop.
Go to p.75 to view the necessary pre-requisite steps and then the procedure to remove the thermal cooling assembly. This will give you access to the fan so that you can check if it is OK (clogged with dust?) or if it is faulty and needs to be replaced.
If it is faulty then replacement fans are available online. Just search for Dell Inspiron N5110 fan or use the information from the label on the fan itself, to find suppliers that suit you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Forg Eex 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 111
