baseband programmer iPhones 6.7?
Baseband programming? Where to buy such a programmer and is it possible? https://zhuanlan.zhihu.com/p/43620005 or is it also for models in the pictures you can see that it is programming the baseband.
I have not seen one of these programmers. The one you are referring to could be used on iPhones before they introduced the Qualcomm Baseband. As far as I’m aware you cannot write to the Baseband QUALCOMM CPU.
In any event the basebands become faulty usually due to an internal short so you wouldn’t be able to read the information on it to start with.
On the iPhone 6 the common baseband fault a Brocken trace due to flexation. You can fix this with a jumper wire and a reball.
On the 7 series if it is a Qualcomm phone it is usually one of two things, either the baseband PMU has failed sending high voltage to the baseband CPU causing an internal fault or it has had an attempted audio repair using too much heat causing the under filled baseband CPU to fail. This can be fixed by a reball.
On the 7 series if it is an Intel it will always be after an audio repair attempt and the baseband can be reballed.
这个答案有帮助吗?
I know that I can not replace or program the baseband ic but the description shows that the description can be programmed for iphona5s I thought maybe there is something for newer models. or I misunderstood because Chinese was translated
@adiap No there is nothing for newer models and there probably never will as apple have made it so from iOS 12 you can update the iPhone with another baseband installed. It will not be a proper phone but you can retrieve the data from it whereas before the data was gone for good.
hello there are other eeprom programmers and there is baseband on my link. Look again at the photos
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 209
