跳转到主内容
这是三星Galaxy Note 20 Ultra 5G Android智能手机的维修和拆解信息。发布于2020年8月。
Front facing camera not working after service pack replacement
I recently repaired a friends Note 20 ultra screen with a service pack. The repair went well with swapping all the original parts over. However when we booted the phone the front facing camera will not work. I went through and pulled the original camera from the original housing to try that. Since the service pack came with one in place I thought maybe it was faulty. However even after using the original and going through and factory resetting and doing everything I could find online to do still no dice. The front facing camera still will not work. Anyone run in to this issue or know how to potentially remedy this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
You need to use the original front camera or buy the same version.
这个答案有帮助吗?
得分 1
添加一条评论
Cameras are serialized to the motherboard both front and
这个答案有帮助吗?
得分 0
1条评论:
Its a part you need to make sure the description of part says serialized
完成的
添加一条评论
there is a bad update that’s been out since the beginning of this year for s10/note10 and up. It has been making the front camera not able to be recognized by the motherboard. I have had it on a few note 10s, s20s and note 20s. No matter what camera you try, usa international or original havent worked for me. Many people have had this issue after they updated their phone.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kyle Tanner 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 2,068
