跳转到主内容
A collection of guides and support to help with washer repair.
3478 个问题 查看全部
Frigidaire GLWS1339CS washer stops at rinse cycle
My washer stops at rinse cycle. Water is drained properly after wash cycle but the washer just shuts itself off after, no hum, no noise. It only works when I manually turn the knob to the spin cycle. The cold water line works because I always wash on cold/cold. The drain hose also works and doesn’t have any overflow issue. What would be the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
Does it also do this when either the Permanent Press or the Delicates wash cycle options are selected?
It sounds as though there may be a problem with the timer in the washer part #8 -Control Panel parts diagram.
The timer is an electro-mechanical device where a motor steps around and operates electrical contacts via cams, at the selected time in the wash cycle to cause different functions to occur e.g. operate water solenoids to fill washer, operate main motor to agitate, drain pump operated, operate main motor to spin etc.
You can view the electrical circuit for the timer in the Wiring Diagrams for the washer in the parts diagram link above. The timer circuit is shown in the block on the left side of the wiring diagram. You will see all the contacts and the cams that are necessary for the operation of the washer.
Unfortunately if a contact or cam has worn it is hard to replace as there are no internal component parts available for the timer and the whole timer has to be replaced.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Han Hua 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 196
