跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 个问题 查看全部
Blinking horizontal lines on screen, disappeared and reappeared
I have a 2012 MBP retina and the screen just started showing a few blinking white horizontal lines on the screen. Later it went away and then reappeared with even more lines. Over the past week now it has grown and there seem to bee hundred of lines making the screen quite unusable. Occasionally a large portion of the screen image will begin jumping up and down very fast making it impossible to even look at the laptop.Does not happen on external monitor, the lines persist in recovery mode and after resetting NVRAM and SMC. I also tried reseating the logic board cables.
I felt like this may have began after I updated to OS Mojave but can’t be sure. I have no ability to get it repaired at a shop due to my location. Would it be worth it to install a different OS version? Order a new display cable abroad? Or purchase an entire new display assembly and replace it myself (I did this before actually after i dropped the laptop 2 years ago).
Thanks so much for the help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can you take a picture or short vid from your phone and post it here so we can see the lines 在已经存在的问题里加入图片
Are you able to connect an external display to your system? If you are do the lines show up on it as well?
完成的
Hey thanks for the reply! I just added a video and yes I can hook up an external monitor okay and there are no lines.
完成的
添加一条评论
1个答案
已选择的解决方案
Well, I think that makes it clear your internal display has an issue.
Time to replace it MacBook Pro 15" (2012年中)Retina 显示器组件更换 Here’s one option for the needed part Retina MacBook Pro 15" Complete Display (12/E13), Apple P/N 661-7171
Sadly, Apple had a large issue with the antireflective coatings (StainGate) and on some issues with ghosting as the T-CON logic also had issues as well. Because of both of these issues finding a good display is hard to find in this series as the part has long since stopped being made (only recycle units available).
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
barry charles 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 614
