跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
I can´t update the firmware
now im running MacOS catalina in the MBP mid 2012 and i have an old boot ROM version but when im going to update it says that a i need MacOS 10.9.5 so what can i do?Also the SMC version has the last one updated, so why is this updated but the rom no?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
How have you updated your system over the years? Have you been upgrading each OS release in turn?
Also what is your current drive a HDD or SSD?
完成的
yes i have been upgrading but when swap to the ssd I install clean Mojave and then update to catalina and im currently using an ssd
the boot rom version that i have is 233.0.0.0.0
also, is necessary to do the SMC and nvram reset even when i have no issue?
完成的
添加一条评论
1个答案
I guess I’m confused here? Boot ROM Version: 233.0.0.0.0 is the correct one for your system. It offers the needed update for APFS boot up.
I have a 2012 15” and my SMC Version is: 2.1f175
As far as SMC and NVRAM resets: I rarely need to do either. So unless you can expand on what you are encountering I suspect you are not addressing the real issue here.
这个答案有帮助吗?
得分 0
2条评论:
@danj i check the apple support website About EFI and SMC firmware updates for Intel-based Mac computers. and it says my mbp 13 mid 2012 (9,2) should have this ROM version:MBP91.00D3.B0C and the mine says 233.0.0.0.0 , so you are saying those versions are the same?
完成的
@sebasg - The TN you found is old! Apple no longer maintains the firmware listing! Since introducing Gatekeeper Apple is constantly upgrading the systems firmware with updated signature files.
完成的
添加一条评论
添加你的答案
Sebas G 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 641
