跳转到主内容
2, 2.26, 2.53, or 2.66 GHz Core 2 Duo processor
106 个问题 查看全部
Apple Install Disk versus Ubuntu EFI
Trying to upgrade the disk in the mini I ran into a problem. It seems that if Ubuntu is installed first, the Apple Install disk isn’t even seen as a bootable disk. Using Alt to invoke the boot manager, only the Ubuntu/EFI partition showed. Just as a band aid I grabbed a new disk and installed it. Then the Apple Install was bootable and the install went smoothly.
How do I get rid of the Boot Manager Ubuntu installed so I can put Apple OS on that disk ? Now if I had a drive enclosure then I’d put it in there and use Disk Utility, but I don’t. Nor do I have a two disk system except an older Mac Pro that might run OS 9.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You will need to reformat the drive fully as I outlined in your other posting: How to reformat an SSD?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James Walker 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 82
