My toshiba tv, model: 32D3753DB turns off and on automatically
The TV only used to do this once or twice a few months ago so I thought it would just be because I hadn’t pressed any buttons or done anything on the tv for a while, I have checked I have no timers on my tv it is not set to turn off automatically. Recently my tv is turning off now 3-4 times a day, even when I just put a programme on the tv it’ll just shutdown and turns itself back on. Sometimes it stays off tho and won’t turn on by the remote so I have to unplug it and replug it in to turn it back on any ideas?
Is there a chance there is something wrong with the power supply cable, or even the power socket its plugged into?
由 Skyler 完成的
Hi @alexmck13 ,
Try removing the batteries from the TV remote and any other remote in the same room e.g. Firestick remote etc and check if the problem still occurs.
Use the TV control buttons to operate the TV in the meantime
由 jayeff 完成的
Thankyou for your response unfortunately I’ve done this quite a few times nothing seems to happen I’m used to using the control buttons x
由 Alex 完成的
