跳转到主内容
第六代 iPad 发布于2018年3月。拥有无线局域网和无线局域网+蜂窝网络机型,32GB 和 128GB 两种储存容量可供选择。配备了 9.7 寸的 Retina 视网膜显示屏和 64 位架构的 A10 Fusion 芯片。
221 个问题 查看全部
Touch screen replaced, iPad touch not registering fingerprints.
Replace touch screen in two stages, first took about 2 hours to remove old screen.
I was pretty meticulous and careful.
When I came back to place on the new display, my daughter had inadvertently turned the device on without my knowledge. Ahhhhhhhhhhhhhhhhhh!!!!!
So the rest was done live.
At no stage did I remove the home button from its motherboard connection, didn’t overstretch it. Was very careful.
Home button worked great so I completed installation, only to find that the fingerprint sensor was registering squat diddly. Yip, shouldn’t have completed assembly, but daughter had an appointment and I had to get home.
So tried the usual, delete fingerprint, turn touch id off/on, with power cycling in between the steps. Home button+Power button restart.
There must be some comms going on as when you try to add fingerprint, it gets to the “Place Your Finger” display, but touch id does nothing.
Factory reset worth trying? Or just accept its dead?
Have apple done an “update” that pairs the touch screen to the home button that I dont know about?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
As far as we know apple didn’t push an update that would disable the fingerprint sensor when the screen was changed *cough Samsung cough*. Inspect the cable and make sure there aren’t any tears or creases in it. Also disconnect and reconnect the cable. You may have nudged the cable out of place so it may not be working properly. Just make sure you disconnect the battery to ensure it doesn’t have power at all during repair.
这个答案有帮助吗?
得分 0
2条评论:
Thank you, yes, it is a possibility that it moved. Just not very keen on opening it again, in case I damage the touch screen and have to replace it again. I was hoping that the home button operating plus the touch id not disabled, was an indication that the touch id problem was probably software related! Thank you very much for your time. I do appreciate it!!
完成的
Yes, I will next time *cough disconnect battery cough* and not be so darn lazy!!!
完成的
添加一条评论
添加你的答案
Biskwit2 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 42
