跳转到主内容
A1706/EMC 3071—于2016年11月上市,这台13''MacBook Pro带有OLED触摸条。以双核“Skylake”英特尔酷睿i5 CPU和4个雷电3端口为特征。
241 个问题 查看全部
Data recovery on bad vodka spill
Basically, our cat knocked over a bottle of vodka on the laptop in the middle of the night. The laptop was soaked. We dried it for a day and it won't turn on. My plan was to take out the harddrive and put it in an external shell to get the data off the computer. It ends up this model, harddrive is soldered to the mother board. Any ideas on how I can recover the data?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Was the cat drunk ??
Sadly there is little you can do here. Hopefully you’ve been good with backing up your data in some manor (local external drive or iCloud).
If you have data that is very important on the system then you’ll need to get another exact same system (late 2016 13” MacBook Pro) which you can swap out the logic boards. Or, the other option is to use the Apple Customer Data Migration Tool (CDM) Here’s how its used This is Apple’s special tool to help customers recover data from the MacBook Pro’s non-removable SSD only the 2016 and 2017 models offer this ability and the logic board drive logic needs to be in working.
In both cases you need to use the same system to migrate your data to.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Kevin ess 将永远感激不已
浏览统计数据:
过去 24 小时: 9
过去 7 天: 10
过去 30 天: 10
总计 53
