跳转到主内容
发布于2018年10月26日。型号A1984,A2105,A2106,A2108。 提供GSM或CDMA / eSIM,nano-SIM或双SIM / 64,128或256 GB /黑色,白色,蓝色,黄色,珊瑚色或红色。 (发音为“iPhone 10 R”)
468 个问题 查看全部
Quiet ear speaker after screen replacement
I replaced the screen with the ifixit kit and while everything is working, including faceid and true tone, the earpiece speaker is very, very quiet even at max volume. Pressing speaker button on a call works as normal and the speaker is great, but in ear on phone mode, it’s way too quiet.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I managed to fix this but it was a pain. I reopened my device and followed the screen repair walkthrough up to removing the speaker from the screen. At this point, I tested just the speaker not attached to the screen and it was very loud and clear, which meant to me that there was an issue with the speaker grill. Below is what I did to fix it.
Before attaching the sensor module to your replacement screen, ensure there is nothing blocking the earpiece screen on the new screen part. Mine had a mfg defect or something where there was a black foam like film on the outside of the speaker grill that I couldn’t remove with tape or sticky putty. I had to blow through the back of the grill with a computer duster compressed air can. Otherwise the call volume via the earpiece is extremely low, even when turned to max volume.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Colin Wylie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 17
总计 678
