跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
15" MBP 2015 DG 4TB SSD upgrade
I recently purchased a Grade A used 15” MacBook Pro 11,5 Dual Graphics 2.8GHz 16GB RAM which I have upgraded with the OWC 2TB Aura Pro X2 2TB SSD. This is an excellent system with great performance, and replaced my previous 13” MB Pro 2012.
My only minor gripe is with the size of the SSD - I’m not going into detail, but I genuinely need to have more than 2TB of SSD internal storage, my old system had 3TB internal storage (after taking out the CD drive), and had it not been that it was getting too old and slow for my needs, I would have gladly kept it just because it was so easy to upgrade everything.
I am aware that Sabrent manufactures both 4TB and 8TB NVMe M.2 Gen.3 blades, which have similar performance to the (excellent) OWC I own and can be installed in my laptop using the Syntech NGFF to M.2 adapter, but I am concerned about thermal issues with a larger NVME blade, and whether this might cause some erratic behaviour when CPU and GPU get going. I have found hardly any information at all about such an upgrade on the web, and before I commit to spend another £500 on an SSD, I’d like to hear from anyone who might have tried the 4TB configuration (8TB is excessive from any possible point of view!) and ask them if they found the system stable.
To reassure anyone about my present system: I am quite experienced with Mac upgrades and found it very easy to upgrade the SSD on this system (with the right screwdrivers, of course), I’ve been running this laptop flat out for about 6 months now, and it is very, very stable. I started on Mac OS High Sierra (I generally try to be 2 Mac OS behind latest, for stability and compatibility reasons), but I’ve just upgraded to Mojave without any hiccups. I regularly have at least 8-10 apps open at all times, Firefox browser with at least 200 tabs open, Mail, Keynote, Numbers, Pages, Zoom and various audio apps (Logic, ProTools or Live, Loopback, Dante etc.) which I use for lecturing. I very rarely get apps to hang and overall found this to be a great rig for a fraction of the cost of a new MBP.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
@marcomigliari - It sounds like you are not a video editor or someone who is working with music composition.
You're more someone who needs access to large quantities of data (presentations & research)
Is that correct??
完成的
@danj I work in music production, but I have a separate Mac Pro at my studio for that, this is my lecturing laptop. I need to have easy access to my most important work from the last 15 years without an internet connection, even though I also use cloud storage for information I don't need often. External SSDs are cumbersome and more fragile, so sometimes it's worth going for the easiest option rather than the most economical. This 2015 MBP should see me through hopefully another 5-6 years - hopefully as long as my previous one lasted. I just wish Apple stopped making stupidly thin and light laptops that cannot be upgraded - this planet doesn't need me to buy a new laptop every 2-3 years, but update my existing one every 2 years instead with more RAM, larger SSD, even a faster CPU. It just takes some thought during the engineering process like they used to!
完成的
添加一条评论
3个答案
已选择的解决方案
I would stick with the OWC SSD! There is too many issues with the M.2 SSD’s using an adapter. I just cleaned out a large drawer of dead SSD’s and adapters I have been pulling out of Mac systems as they just don’t hold up.
As far as thermal issues of a larger 2/4 TB blade SSD. Given your workflow you are not rendering, just running slide ware and finished music/videos. At most, you might show a quick example of editing on a small music/video which will not be very long. So you are not keeping the system churning! That would be an issue.
I would recommend getting a good thermal management app like TG Pro It’s what I use. If you are going to push your system you can ramp up the fans which will also cool your SSD and as the app can access the SSD’s onboard thermal sensors you can watch whats happening.
Heat sink design
This is the ideal heatsink design to shed heat. Offers a good balance of Mass and air heat transfer, you still need to have enough air flow.
The other design is to use the case as the heat dump using a similar design Apple used in the their early iMac systems
这个答案有帮助吗?
得分 2
3条评论:
Thank you for your reply, what you wrote makes sense. I wonder if the issue with NVME adapters is with supply current eventually baking PCB copper tracks? Years ago I fried a HD flex cable in my previous MBP, found replacement on EBay and all was well, but I suppose on NVME an adapter failure can be a bigger issue. Really appreciate tip on TG Pro, sounds like a great idea and it’s cheap, so will install it tonight.
完成的
I too am looking to upgrade to a 4TB. I am out of space. I wonder if a 4tb will work. I am very tempted to give it a go with the Sabrent and see what happens.
Anyone actually given it a try yet?
I upgraded mine to the 2TB Samsung EVO 970 Plus about 2 and a half years ago. I had some early kernal “panics” in the first year or so, then seemed to have really stabilized. I get one very infrequently now. I was a glutten for punishment here as people online specifically warned not to use this particular model of Samsung ssd. But hey, I wanted to. It is an awesome SSD.
It was an extremely worthwhile upgrade! It does heat up and run the fans frequently, but this seems to have greatly reduced in frequency with the upgrade to OS Monterey.
I keep my original Apple ssd to periodically re-install it and perform OS update on it. Apparently this the only way to update the MBPro firmware, boot rom or something like that etc.
完成的
@arizonabay - So you like playing Russian roulette! So you got a small flesh wound with the Samsung now going for something a little deeper this time?
Really! Is your apps & data not that important? If you are in school are you going to use the computer ate my homework as your excuse? Or loose your grand parents photo presentation for their big family 50th Wedding Anniversary?
OK I get it its the cost! But is it worth it?
Go for either a real Apple unit or OWC unit.
完成的
添加一条评论
In my own research, I’ve found no widespread reports of failures using recent M.2 adapters from Sintech, especially when paired with Sabrent 2280’s. In fact, Sabrent 2280’s seem to be quite reliable. OWC upgrades, on the other hand, have a reputation for problems, particularly regarding overheating. I built my first computer back in 1979, and I can confidently say heat is the biggest enemy of electronics. (My kitty once urinating on my old receiver not withstanding!) So Marco’s concern for overheating is quite understandable. The biggest reason I didn’t upgrade my memory years ago with OWC was out of concern for overheating. Sabrent 2280 sticks are some of the lowest wattage SSD’s on the market today. Low power equals low heat. As for the issue of losing data, everyone knows if you don’t back up your data, you’re asking for trouble. It doesn’t matter what kind of storage you use, sooner or later, it will fail—100% guaranteed. The reason I just upgraded my own MacBook Pro was because its original SSD failed.
这个答案有帮助吗?
得分 0
4条评论:
@AnnoniMoose - Last year I threw out 30 M.2 SSD's and a few different adapters, many Sintech.
The generation of OWC drives is likely what you noted as the early ones did have issues.
Part of the problem is similar to what got Intel into trouble pushing density without improving the process Node so the cell logic spacing is smaller and runs cooler.
The biggest issue with M.2 SSD's is the simple fact Apple has lines between the SSD controller and the logic board the M.2 and adapter have no concept of dealing with. These lines involve sleep mode, garbage collection and TRIM services.
Yes! day one the M.2 SSD will work! But as you use your system if you put your system to sleep (closing the lid) while some of these processes are running you can leave incomplete recovery of the cell block.
Think of it this way You have a 1000 bullet chamber with a few bullets scattered so the chance of getting shot is present but its not easy! Now let's reduce the chamber to 500, then 250 and then 75. The probability increases! So as the drive is more used and full the risk increases!
Now someone who fails to be a good at backing up may end up having a sizable loss. If you are a pro under deadlines getting hit by this bullet is not what you want!
I deal with advanced amateurs, students and pro's who do photo, video and music production. Which is likely why I see the failures more so than others.
完成的
The issue of SSD heat is a bit over blown The flash chips run better when on the upper warm side (not ultra hot) the controller runs better being cool!
The write operation to the flash is the heaviest heat point. So a few hits at a time no big deal a massive write can be a real cooker!
The physical size of the blade SSD also creates an issue. A low density drive (128, 256, 512 GB) has more space to work within, a high density drive (1,2 & 4 TB) less as well as the flash cell logic density also needs to be considered (9, 7 or 5nm)
Now the next issue is shedding the heat! We have two elements here Mass and Heat Movement. Many people just think a larger heatsink Mass is all thats needed, pasting a thick strip of copper or metal block, that works to a point for small write/read operations. But, once the heatsink is at its thermal equilibrium with the chips it offers no further benefit!
Yes, just like a tea kettle over time the heat will radiate off but the speed is the question! It is just not fast enough here!
So that pushes us to Heat Movement transferring it to the external world in some way. Just like a CPU chip we can go full tilt with a set of heat pipes to move the heat to a second mass which has a set of fins with a fan blowing across or we can use a heat sink which has a large air surfaces either leverage the systems fan to pull the heat away or transferring the heat to the external case skin (metal)
Lastly the size of the fan makes a big difference, don't get caught up with these Heatsinks with a fan they really don't help as the fin area is not large enough to shed the heat.
The last bugaboo is the mating surfaces of the chips to the heat sink. Ideally the thinner the material the better and removing labels is also important as they tend to reduce the heat transfer as well. We sometimes need to use different thicknesses of thermal pad (and type) if the chips are at different elevations (we need good compression as well). Again to be clear thin is in! The thinner the thermal pad is the better as we want to move the heat to the mass so the chips are at their ideal heat level.
We also can encounter needing to transfer the heat from both surfaces (many newer Blade SSD use both sides for holding the flash chips) So we have to bring the heat from the back side to the upper side and using adapters can get in the way as well as close spacing to the logic board.
So there you have it the fine art of SSD cooling!
完成的
The heat issue is a real issue. But as mentioned, it depends on a lot of factors. The issue of compatibility also depends. There are many things to consider.
As with OWC improvements over the years, so have other products. That includes the adapters, storage chips & circuitry, and even the Macs themselves. For instance, 2015 MacBook Pros don't have the same sleep issues as previous models. Samsung blades use much more power than most others. Sabrent makes some of the most efficient. Trying to save a couple of dollars on cheaper adapters isn't wise. Just like it's unwise to buy counterfeit power supplies or aftermarket batteries. Save a few bucks now, and pay a lot more later. You rarely get more than what you pay for.
So before jumping in and spending many hundreds, on anything, do your due diligence!
完成的
@AnnoniMoose - No! The M.2 Spec has not been altered the signal lines are the same as day one. The issues are the same across all M.2 SSD's and adapters - Then and now.
Refinements in the technology helps that's for sure! That is just what Apple has done with their own SoD development. But they own the AP across all of the elements of the iPhone and now with the M series SoC's they own it too.
Sabrent Vs Samsung is a pontless argument as you missed the point! This is not which M.2 SSD is better, it is what plays within the system without failure. I've taken out both M.2 SSD's out as they failed!
The custom Samsung SSD's made to Apples specs are different! Extra data lines and the SSD's micro-controller uses a different code set (Samsung modified by Apple). OWC as well as Transcend made the effort to fully emulate the interface and micro-controller firmware functions. If the M.2 SSD's offered this same level of compatibility I wouldn't have any issue using them.
I'll agree Apple messed up! They should have stuck with the M.2 standard than doing their own thing. Getting the needed alterations to the interface (added signal lines) at least within the M.2 standard (and the standards group should have listened to the needed alterations). Apple closing things off like they did was a mistake!
I like M.2 SSD's! I used them in my AMD Threadripper system which is now doing my heavy large image processing I do as the 2019 Mac Pro was outside of my budget. Sadly, its never got its chance as COVID has mostly sidelined me.
I posted an image of the heat sink design that is ideal above. I had gotten 20 custom units to setup a few systems for video rendering.
完成的
添加一条评论
My Samsung 970 Evo Plus 2TB is still working, but it still runs hot. I think the heat over the almost 3 years now yes what finally did my battery in. I did get the TG Pro fan monitor software, and I just replaced my ballooned battery, put new thermal paste on the CPU and GPU. But still looking for ways to lower the heat. Even if I have to move to another brand that runs cooler.
Overall, the SSD has been a completely awesome upgrade, and has been a risk worth taking, for me at least.
Soooo,
Has anyone tried the 4tb ones yet in a Mid 2015 Macbook Pro? e.g the Sabrent?
Can the MB Pro handle 4tb?
Thoughts on lower heat SSD? Someone mentioned Sabrent. Others? I also would like to maintain Samsung's performance as best as possible
Has anyone tried adding these type heatsinks for the SSD? https://www.amazon.com/gp/product/B07YC1...
Any ideas would be greatly appreciated.
这个答案有帮助吗?
得分 0
2条评论:
@arizonabay - A 4TB SSD will in fact run hotter!
This gets complicated! The major issue is the density of the flash cells get tighter the hotter the logic runs as you use it. So with two SSD's that use different density of chips of the same logic generation the less dense will run cooler! Likewise an SSD which uses more chips also runs hotter. This follows the same problem HDD's a CPU's faced as there density and performance improved they too got hotter. Dammed and double dammed!
So what to do?? Laptops don't have the space to add proper heatsinks and the benefit of a heatsink only goes so far. We often forget the function of a heatsink is two fold: one to offer a mass to hold the heat and a means to radiate it away. With CPU's/GPU's we can see the full solution a large block of metal to transfer away the heat, a means to move the heat to a set of fins which has a fan blowing across.
Sadly these M.2 copper blocks only offer the mass and no means to move the heat away. Think of it this way you have a cup and you fill it with water it can't hold more than what the cup can hold, so once these get to temp you can't add more heat to them and as there is no fins to allow the fans drafting to reduce the heat buildup more quickly you don't really improve things as its not the short hits that we worry about its the long write events.
Here we are dependent on the drafting of the fan to pull the heat away but we don't have an effective means to move the heat away directly from the flash chips or space enough for the mass and in this case a passive fin design for the air to run through to pull the heat away.
Then the question is, is the heat buildup within the SSD bad? As it turns out writing works better when running hot!
Don't forget we also don't want to cook the rest of the system either! The answer here is just install a good thermal monitoring app which can also push the fans as the temp gets above a level. I use TG Pro which is one of the best ones out there.
The other issue is being dust free! A system which is loaded with dust and debris will run hot as the ability of the fan to cool things will be impacted but the junk! The last issue is the battery, surprisingly an old battery or one that is well worn requires more power to charge or hold a charge (adding more heat)! So a system which has a battery over four/five years needs to be replaced as well as one that is getting about 850 cycles or more.
I might add your workflow is also a factor here! Massive data work like video rendering also wears the drive faster! It also requires more housekeeping to keep it running. This is where Wear Leveling kicks in which then can push the heat as well! As a cell which has data that is more worn is transferred to a cell that is less worn. So consider your use, maybe it would be better to use an external drive instead!
完成的
To get more out of your 2TB drive I would recommend you unload some of the stuff you have on it as the more free space it has the less work it has during Wear Leveling which is likely a big issue here if you have less than 1/4 of the drive empty.
完成的
添加一条评论
添加你的答案
Marco Migliari 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 31
总计 4,945
