跳转到主内容
Released April 2013, model numbers GT-N5100 (3G & Wifi), GT-N5110 (Wifi), and GT-N5120 (3G, 4G/LTE & Wifi)
How do I check which component can be defective?
Galaxy Note 8.0 GT-N5110 does not display anything and makes no noise when the charger is plugged in and will not turn on.
How can a removed battery be checked?
There are 6 wires on the battery: 2x red, 2x blue, 2x black.
With multimeter I measure 4.2V between black and red. is that still ok?
What defect do you suspect behind this?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Well you should’ve successfully determined it’s not the battery with your multimeter. Just make sure the reading is somewhat close to what’s posted on the battery label. If it’s slightly above that means its fully charged. If it’s slightly below it means it’s drained but should be enough to power it on. And if it’s way below then you have an issue with the battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hans Rudolf Studer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 116
