Switch not charging Joycons
I am having an issue with my Nintendo Switch not charging my joycons. I purchased used without joycons. I tested the unit with a pair of brand new joycons and they would not charge. I also tried a Hori D-Pad controller that I got on clearance from Target. The hori unit has no battery and can only work when docked. It not working shows the joycons are not getting any power. There is no damage to the joycon rails. The system is in good shape.
I read a few questions here and saw someone mention replacing the fan could fix this problem. I did that and it didn’t fix the problem. I do notice the console is a little warm. How noticeable is the fan spinning up? I don’t know if I really noticed it spinning up before I replaced the fan and I am certain I connected the replacement. I should also note I put some new arctic silver thermal paste on the unit when I replaced the fan. Is there anything else that can cause the unit to not charge the joycons?
The unit works fine and I can used it docked with a controler, but it would be nice to have it fully functional.
