跳转到主内容
Front camera and Face ID stopped working after disassembly
Hi friends,
I teardown my pixel 4XL to replace rear camera. But when I assembled again, my front camera and faceid can not work. Face enrollmend didnt work , front camera black screen when flipping from.rear camera to front camera. I am quite sure I teardown carefully.
Really appreciated your help.
Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
I too am having the same problem I even replaced the front camera and sensor assembly. The camera app doesn't work for front camera at all. It dose however show a B&W imagine on other apps but it isn't using the camera but the sensor to the left of it.
这个答案有帮助吗?
得分 1
1条评论:
were you able to find a solution to this? i am having the same problem. already replaced it and yet nothing on camera app. i also have the BW on other apps.
完成的
添加一条评论
Well possible reason maybe that the clip connector is not properly connect to the main board, which will cause the face id not to function as well and also result to the black screen when camera flips from rear to front.
Or the flex connector connected to the main board is cut now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tan Vo Huu 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 8
过去 30 天: 23
总计 561
