跳转到主内容
2020年4月宣布和发布的第二代iPhone SE的维修和拆卸信息。
243 个问题 查看全部
Can I use iPhone 8 lens on SE 2020?
The glass cover on my SE lens is cracked. I see that the housing for the SE 2020 and iPhone 8 are supposed to be identical, though not all parts are interchangeable. The iPhone 8 lens part listing on iFixIt doesn’t mention the SE under compatibility. Does anyone know for sure if it will work before I take the plunge and try it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
If you are just looking to replace the rear camera lens, I believe those are the same size and can be swapped, especially because the cameras themselves can be swapped between the two. As for the whole housing, unfortunately Apple made some changes to the SE housing that prevent you putting an iPhone SE inside an 8 housing (and vice versa).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jvbh 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 291
