跳转到主内容
加入维修社区 - 创建账户
发布于2016年3月,是一款同时拥有着iphone 6s般的硬件规格以及4英寸屏幕体积的iPhone。有深空灰色、银色、金色及玫瑰金色四种配色以及16/64GB容量可选。国行型号为A1723和A1724。
iPhone SE passcode loop
Iphone SE - light water damage.
Phone boots up nicely but freezing after putting last digit of the password. (A little googling and found that NFC ic could do that).
Removed board and it was a bit corroded around U5301_RF chip. I was missing STOCKHOLM 5V (it was showing 0,6 V).
So changed the U5301 and also U5302 - now the result on STOCKHOLM 5V line is showing the VCC_Main value and not booting the line up.
What value has to be the enables lines?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I would suspect the enable lines to be 4.1V “VCC_MAIN voltage” and that is what I would expect from the STOCKHOLM 5V line to be if you were measuring that line with the logic board out of its housing.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kaspar 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 121
