跳转到主内容
加入维修社区 - 创建账户
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
does washer have filter
mdl#cw4571379
does the washer have a filter
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @laduckster ,
Please verify the model number as the number that you posted shows no results?
完成的
添加一条评论
1个答案
Usually washers have two filters. One filter is for your water pump and the other is for your built-in lint filter. Washers nowadays usually just have one accessible one and that is the water pump filter. The lint filter like I said is usually built-in on all the newer washers and therefore it is hard to access and clean. But if you can it will greatly increase the life of your washer. Usually the lint filter is located below the tumbler on the front end loading washer. And behind the washer if it is a top loading or on the side. If you can clarify the make and model number of the washer. It would be a quick fix and help. Any problems?
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
yohan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 10
总计 3,173
