Capacitor Value on Motherboard next to Power Supply Plug
hello,
i need the value (???uF) from this capacitor. I guess an smd cap with 35v rated should be enough, because there should be only 5V / 12V coming from the power supply. But i don’t know the value of it. Thank you for your help.
Specs:
PS4 Pro CUH-7016B
Motherboard NVA-001
Let me know, if you need more information.
Thanks again.
3条评论
I have same problem and i need to know this capacity value (??uF) , if any body know please tell me
由 Payam N 完成的
@Payam N Hey Payam, i soldered a 10uf in the same size. as i mentioned already it is only for the power on sequence of the board with only 5v standyby voltage. so just use one in the same size with at least 10uf. worked for me. good luck
由 Selim Karakurt 完成的
Dear Selim its a huge help for me thank you so much.
由 Payam N 完成的
