Desoldering Wifi Module Problem
I have put the hot air station to 450 degrees and the module will not even budge any idea please i also tryed on the nor but same. The Ps4 was in storage for some time does this effect the solder. there is no way to put quick melt solder on pins as they are under.Any help please
2条评论
did you put enough flux btw?
由 Augustine 完成的
HI Augustine Yes i put but it seems not to go under the chip
由 Kenneth Camilleri 完成的
