跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Stuck in boot loop after entering passcode
Hi,
got a iPhone 6 that was not looping , after I put in recovery mode and then exited it the phone started normally and went to passcode screen, after putting in last digit of passcode phone froze amd then went into boot loop again. Re flashed the phone on 3u tools amd passcode screen come up, after entering passcode it froze again on last digit and goes back into boot loop.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
There could be a lot of reasons your phone is acting like it is. You should try another screen, battery and dock connector to rule out a parts issue.
You said you flashed it with 3uTools. I gather you had the retain users data ticked? If you previously forgot the passcode and entered the wrong one too many times this is what I would expect to happen.
If you didn’t disable the phone by entering the wrong passcode the problem will most likely be a fault on the NFC circuit on the logic board which would require a reputable repairer to fix.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
dan morrill 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 815
