跳转到主内容
Second generation of the Fairphone, made by the social enterprise with the same name. Released in December 2015. Model number: FP2-XCVR
I need to put my speaker on when calling
I have a Fairphone 2. it still works quite okay, I only have the issue that the one receiving my phone call doesn’t hear my voice unless I put the speaker on which means that I don’t have any privacy anymore as everything we talk about is loud and clear for everybody :(. What do I have to replace in order to solve that problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Hi,
First use a strong light and a magnifying glass and check if you can see if the voice inlet hole on the bottom edge of the phone appears to be blocked at all. If it is or if you’re not quite sure, do not use a pin or probe to try and clear it as you may damage components in the phone. Try using a vacuum cleaner to suck out any obstruction.
If you still cannot be heard on a call, most probably there is a problem with the primary microphone
Here is a link to the ifixit Fairphone 2 Microphone Module Replacement guide that will help.
There is also an app available on the phone that allows you to test the primary microphone as well as a lot of the other hardware in the phone which may also help.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Rina Teeuwen-van der Ende 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 315
