跳转到主内容
Device repair and troubleshooting guides for the HP Pavilion 13-s128nr x360, a consumer 2-in-1 laptop by HP released in September 2015.
21 个问题 查看全部
My laptop power button is flashing and it won't turn on
Hey I need help my laptops power button is not working. It first started when I decided to use it was broken but I needed something from the laptop. I had dropped but i didn’t think nothing of it. When I turned it on worked. I needed internet so i went to my living room then it died and when I tried charging it the power button was flashing. I honestly don’t know what to do send help.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
If the caps light and charge indicator blink, that’s usually RAM with HP laptops. Take the laptop apart so you can get to the RAM and reseat it, as it often helps. If it isn’t loose RAM, you may need to replace it.
The HP service manual can be found here. You need to tear it down to the motherboard on this one to get to the RAM.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Asmier Powell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 22
总计 1,378
