跳转到主内容
Released June 2006, the Dell Inspiron 530 is the first desktop in the Inspiron product line.
14 个问题 查看全部
will this ssd be suitable for these 2 machines? and what sata cable?
hi there, so as ive posted before I am upgrading a dell inspiron 530 and I will be putting an ssd into it so I can boot it from Linux as theres no way im paying 80 quid on a piece of new windows software that’s potentially worth more than the machine its on also ive had bad experiences with windows 10 anyway, so what I need to know is, will this ssd be compatible with a dell inspiron 530? : https://www.amazon.co.uk/Kingston-SA400S...
(I cant link to that for whatever reason so please copy and paste)
I see that there are apparent differences between sata 1, 2 and 3? and that my pc may not be compatible with sata 3 because of its age? if that is the case could any of you link me to another more suitable ssd on amazon instead? it has to be amazon as I have £9 gift card credit on it which I would like to use up, could you also direct me towards the correct sata cable to use with the dell too? I am looking for the best possible ssd and cable I can install on that machine but still somewhat cheap and it seems that kingstons are the most reliable as far as I can tell?
as mentioned in the description, I also plan to install an ssd on my hp pavilion g6 2365 ea laptop and rip out the hard drive as a final solution IF nothing else works (the problems im having with it at the moment have also been mentioned on this forum) so would the above mentioned ssd work with that laptop or is it not sata 3 compatible either?
answers greatly appreciated
thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
It doesnt matter what ssd you use, no matter what speeds it supports. If it supports sata2, and you have a sata3 ssd, itll work, just not at gen3 speeds. If you have a gen 2 ssd, and your pc supports gen 3, you will get gen 2 speeds.
As for the sata cable, just get any ol’ sata cable similar to these, as long as you have a spare sata power cable as well. These are just data cables. I wouldn’t go with the cheapest ones, though.
Cable Matters 3-Pack 90 Degree Right Angle SATA III 6.0 Gbps SATA Cable (SATA 3 Cable) Black - 18 Inches https://www.amazon.com/dp/B018Y2LEBE/ref...
这个答案有帮助吗?
得分 1
6条评论:
So I should just go ahead and get that ssd for the dell computer then? And it will definitely work once I get a sata cable for it? And if I buy another it will definitely work for the laptop as well?
完成的
Also would you recommend that particular model? Are Kingston’s reliable? Is it a great choice?
完成的
@weemawn Look at the specs from the manufacture to be safe. for SATA II. Look at the warranty. Is it 2, 3 or 5 years? No brand is faultless as many different models exist so go by the warranty. But generally now, as opposed to when they first came out, most SSD's are O.K. The choice is yours
Curious about your problems with Windows 10 but you don't say what. And then again the system is fairly old. I have Windows 10 running on a 15 year old DELL laptop. It is not fast but it does work.
完成的
@weemawn Yes, kingston is a good brand. I have used their flash drives, and ssd’s in my laptop
完成的
As long as both are sata, yes, they will work for both your desktop and laptop
完成的
显示更多的1条评论
添加一条评论
添加你的答案
weemawn 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 122
