跳转到主内容
任天堂 Switch 是一款可以通过扩展坞在电视和路上玩的游戏掌机。发布于2017年3月3日。
707 个问题 查看全部
Left joycon no longer work attached after water spill
I accidentally spilled water on my switch, after some testing both of my joycons are working on a different device but any left joycon ist being detected in handheld mode but does charge.
Any one knows what to do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
4个答案
最有帮助的答案
I guess the only way is to clean with a nylon brush. Same happened to mine and you can see the corrosion on the contacts. Mine works but not consistently.
这个答案有帮助吗?
得分 1
添加一条评论
Hello,
This might be due to corrosion on the connector, so plugging in and out the joycon a couple of time should remove the corrosion.
Hope that helped.
这个答案有帮助吗?
得分 0
添加一条评论
Hey. I know this is an old question but I have the same problem on my new oled switch. Please tell me you fixed it and if so how?
这个答案有帮助吗?
得分 0
添加一条评论
I was trying to wash my joycons with water and disconnected and it doesn't the left joycon doesn't work what should I do
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ori Agranat 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 16
过去 30 天: 50
总计 1,747
