跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140 个问题 查看全部
问题已关闭
The screen say "Empty Grinder" - how do I fix it?
The machine seems ready to go- it says "Select shot size" as it normally does- but when I select a size, it starts like it should but makes an odd noise like it can't grind anything. Then it displays the message "Grinder Empty." I've checked both the water and beans and they are full. I've also turned the machine on and off. Help please!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi,
sometimes there are small stones in the coffe beans. When a stone gets stuck in the grinder it might happen, that the machine thinks the grinder is empty. The grinder should start grinding even if there are no beans.
这个答案有帮助吗?
得分 0
2条评论:
Thanks for the help! So should i just try to clean out the beans??
完成的
Unplug the machine, clean out the beans and take a closer look at the grinder. Read the manual what to do if there is a stone stuck in the grinder.
My Jura S70 had a special wrench to turn the grinder backwards in order to get the stone out of the grinder.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 14
总计 612
