跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
Replacing Touch Screen Cable?
Hey,
I found out that the Touch Screen Cable is causing white lines on my screen while it touches from alone etc.
Can I replace this cable like I can replace the Sensor Cable for example?
Or is it merged with the screen and I need to replace the whole screen?
Thank you
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
hello Bajek,
flexible tapes are inseparable from the screen. If the cable is damaged, the entire shield must be replaced. In your case, however, the problem is contact - probably not well placed. Open the phone gently (don't use a knife or other metal objects like a flat screwdriver ...) Use a plastic spatula - if you don't have one, buy one -should cost $ 0.50. Disconnect the batteries first, then the entire screen. Look at the connector, clean it, blow it ... whatever. Reconnect the screen, battery as last !. Check the screen. It should be much better :-)
  • regards and Marry Christmass
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bajlk 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 78
