跳转到主内容
The Pocophone F1 is a mid-tier smartphone made by Xiaomi Inc, announced on 22 August 2018 in New Delhi, India.
51 个问题 查看全部
I send my phone to the local repairshop
I want change my battery and change its thermal paste..
and the repairman broke the phone signal cable connector.. the repairman said water corrode the connection between the cable from the board..
question : can water affect the internal electronic component? can it corrodes the connector? is replacing the motherboard is the answer?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hello, yes water damage can be the cause of many issues and is unpredictable - including damaged chips and connectors on the logic board. It can also worsen over time. Replacing the logic board should fix the issue, however other parts of the phone may still be affected if water managed to get to the logic board. It is also possible the repairman made an error, but his theory is certainly possible.
Hope this helps (:
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
risinghopper 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 72
