跳转到主内容
The Nikon D1X is a digital single-lens reflex camera (DSLR) made by Nikon Corporation and introduced on February 5, 2001.
1 个问题 查看全部
How can I troubleshoot my Nikon D1x - NO SIGNS OF LIFE...
I purchased a D1x from an auction and discovered the included Ni-MH battery included was dead, and would not take a charge. I had the EN-4 battery pack professionally rebuild at a local battery shop and charged with my MH-16 charger. So far, so good. Put the battery pack into the camera body and *nothing* happened! No lights, no sounds, no indicators - nothing :-(
I don’t suspect the battery as it meters out at just over 8v with a DMV after charging.
I don’t have a Nikon EH-4 power supply.
Does anyone have a pin-out for the front power supply input jack? Maybe I have a loose battery terminal connection?
Any other troubleshooting advice is appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Using the power supply connector on the front of the camera body, I was able to apply power using a bench power supply, and discovered the camera powers on :-) Now, I'm going to troubleshoot the battery box assembly to determine if there is an open circuit or broken wire somewhere.
完成的
添加一条评论
1个答案
Try using a toothbrush with some drops of vinegar…and rub gently the battery terminals inside camera body
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jtheires 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 354
