跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
774 个问题 查看全部
Is my DC-In board going bad?
My MBP is having odd symptoms regarding power input. One power adapter will quickly overheat; another will randomly cause the computer to turn off; a third will blink or flicker when plugged in. This all sounds like a bad power-in board to me, but I want confirmation before I replace it (and, frustratingly, there’s no guide for replacing that part on iFixIt).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I am not sure about these symptoms, but replacing the Magsafe board for these requires removing the logic board. Chances are if the chargers are all giving weird power inputs though, the issue lies within the SMC on the logic board. Not 100% though, just my experience.
Around step 42 for removing the logic board, you will have to remove the charge port. MacBook Pro 15‘’Retina显示器2015年中期主板交换
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Calion 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 14
总计 142
